Location of Device Configuration Files
The device configuration files are located in the following directory: %ProgramFiles(x86)%\Mosart Medialab\Mosart Server\ConfigurationFiles.
Note:
Do not modify any files at this location, as they are overwritten by the next installation (update/upgrade).
Copy any files that must be modified to the "
%ProgramData%\Mosart Medialab\ConfigurationFiles"directory, and modify them there.
This ensures that configurations remain valid after system upgrades or downgrades.Historically,
C:\channeltemplateshas been the folder to copy to, but with a few exceptions, Viz Mosart applications will look in%ProgramData%before checkingC:\channeltemplatesfor configuration files.
Name of the configuration file(s)
In the following sections, the configuration files are shown with their default names. For some device types it is possible to specify a different configuration file name in the device connection string.
This makes it possible to use different configurations for various devices of the same type, for example when you have two slightly different settings for two video servers of the same type and brand.
There must be a 1:1 match between the name of the configuration file and the name referred to in the device connection string.
- Audio Mixer Configuration Files
- Engine Switcher Configuration File
- Graphics Configuration Files
- Light Control Configuration Files
- Robotic Camera Configuration Files
- Subtitling Configuration Files
- Video Router Configuration Files
- Video Server Configuration Files
- Vision Mixer Configuration Files
Information about Video Server Configuration Files is in section, Video Server, MAM and Database Connection Strings.
