The table ti_templateimplementation contains the gallery specific template implementation as created by the Mosart template editor (i.e. this information is gallery dependent).
Name | Type | Allow Null | Description |
ti_recno | integer | No | Primary key. |
ti_te_recno | integer | No | Foreign key referencing the corresponding template te_recno in the te_template table. |
ti_ga_recno | integer | No | Foreign key referencing the corresponding gallery ga_recno in the ga_gallery table. |
ti_xml | longtext | Yes | The actual xml-formatted template implementation as created by the Mosart template editor. |
Information: The template implementation must be created per gallery and is stored using its native XML representation, as received from the Mosart template editor
