Variants for Mosart Templates of Same Type
A single MOS object will be created for Mosart templates of same type from the default template set. In this example
<mosExternalMetadata> node contains the list of variants for the Mosart templates, of same type.
<objID> of the MOS object is the template type, for example 0 for CAMERA or 1 for PACKAGE.
<objGroup> is the default template set name.
<type> node has the name set to the template type name (for example CAMERA, PACKAGE etc.), and templateset set to the name of the default template set.
<mosObj> <objID>0</objID> <objSlug>CAMERA</objSlug> <mosAbstract>CAMERA</mosAbstract> <objGroup>Talkshow</objGroup> <objType>STILL</objType> <objTB>50</objTB> <objRev>1</objRev> <objDur>0</objDur> <status>NEW</status> <objAir>NOT READY</objAir> <createdBy> </createdBy> <created>2019-03-04T13:23:38,000Z</created> <changedBy> </changedBy> <changed>2020-03-07T09:22:21,256Z</changed> <description>CAMERA</description> <mosExternalMetadata> <mosScope>PLAYLIST</mosScope> <mosSchema>http://www.mosartmedialab.no/schema/mositem.dtd</mosSchema> <mosPayload> <mosarttemplate> <type name="CAMERA" templateset=”Talkshow” category=""> <variants fieldtype="LIST" value="1"> <variant name="1"> <transitions value="DEFAULT" enable="false"> <transition name="DEFAULT"> <field name="" value="" fieldtype="TEXT" /> </transition> <transition name="MIX"> <field name="transitionrate" value="0" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="WIPE"> <field name="transitionrate" value="" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="EFFECT"> <field name="effectname" value="" fieldtype="LIST" keylist="effects" /> </transition> </transitions> <fields /> </variant> <variant name="2"> <transitions value="DEFAULT" enable="false"> <transition name="DEFAULT"> <field name="" value="" fieldtype="TEXT" /> </transition> <transition name="MIX"> <field name="transitionrate" value="0" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="WIPE"> <field name="transitionrate" value="" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="EFFECT"> <field name="effectname" value="" fieldtype="LIST" keylist="effects" /> </transition> </transitions> <fields /> </variant> </variants> <keys name="mixerinputs"> <k> </k> <k>CAM1</k> <k>CAM2</k> <k>GRAPHIC1</k> <k>GRAPHIC2</k> <k>LIVE1</k> <k>LIVE2</k> <k>SKYPE1</k> <k>SKYPE2</k> <k>PLAYA</k> <k>PLAYB</k> <k>PLAYC</k> <k>PLAYD</k> <k>ME1</k> <k>ME2</k> <k>ME3</k> </keys> <keys name="effects"> <k>1</k> <k>2</k> <k>3</k> <k>4</k> <k>5</k> <k>6</k> <k>7</k> <k>8</k> <k>9</k> <k>10</k> <k>11</k> <k>12</k> <k>13</k> <k>14</k> <k>45</k> <k>47</k> </keys> <keys name="routersources"> <k>SAT_10</k> <k>DEP_01_A</k> </keys> <keys name="routerdestinations"> <k>M_VISU_2</k> <k>M_ROBO_2</k> <k>TESTLOW</k> <k>TESTHIGH</k> </keys> </type> </mosarttemplate> </mosPayload> </mosExternalMetadata> </mosObj>Variants for Mosart Templates of Same Type and SendAllTemplateSets set to True
A single MOS object will be created for Mosart templates of the same type for each template set. In this example:
<mosExternalMetadata> node contains the list of variants for the Mosart templates of the same type.
For example, if there are 3 template sets and 10 template types having 2 variants each, then there are 30 MOS objects created, each having 2 variants.<objID> is the “TemplateSet-TemplateType”.
For example in the ’FuncSpec’ template set, FuncSpec-0 for CAMERA or FuncSpec-1 for PACKAGE.<objSlug> is the template type name.
For example, CAMERA or PACKAGE.<objGroup> is the template set name.
<type> node has the name of the template type name (for example CAMERA, PACKAGE etc.), and templateset set to the name of the template set.
In the example below there are there are 2 template sets:
- FuncSpec having 3 Camera templates and
- Demo having 2 Camera templates.
<mosObj> <objID>FUNCSPEC-0</objID> <objSlug>CAMERA</objSlug> <mosAbstract>CAMERA</mosAbstract> <objGroup>Funcspec</objGroup> <objType>STILL</objType> <objTB>50</objTB> <objRev>1</objRev> <objDur>0</objDur> <status>NEW</status> <objAir>NOT READY</objAir> <createdBy> </createdBy> <created>2016-04-01T11:42:09,000Z</created> <changedBy> </changedBy> <changed>2017-09-22T12:05:20,070Z</changed> <description>CAMERA</description> <mosExternalMetadata> <mosScope>PLAYLIST</mosScope> <mosSchema>http://www.mosartmedialab.no/schema/mositem.dtd</mosSchema> <mosPayload> <mosarttemplate> <type name="CAMERA" templateset="Funcspec" category=""> <variants fieldtype="LIST" value="LIVE"> <variant name="LIVE"> <transitions value="DEFAULT" enable="false"> <transition name="DEFAULT"> <field name="" value="" fieldtype="TEXT" /> </transition> <transition name="MIX"> <field name="transitionrate" value="0" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="WIPE"> <field name="transitionrate" value="" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="EFFECT"> <field name="effectname" value="" fieldtype="LIST" keylist="effects" /> </transition> </transitions> <fields> <field name="xpoint1" value="CAM1" default="CAM1" fieldtype="LIST" keylist="mixerinputs" /> </fields> </variant> <variant name="21"> <transitions value="DEFAULT" enable="false"> <transition name="DEFAULT"> <field name="" value="" fieldtype="TEXT" /> </transition> <transition name="MIX"> <field name="transitionrate" value="2" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="WIPE"> <field name="transitionrate" value="" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="EFFECT"> <field name="effectname" value="" fieldtype="LIST" keylist="effects" /> </transition> </transitions> <fields /> </variant> <variant name="20"> <transitions value="DEFAULT" enable="false"> <transition name="DEFAULT"> <field name="" value="" fieldtype="TEXT" /> </transition> <transition name="MIX"> <field name="transitionrate" value="2" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="WIPE"> <field name="transitionrate" value="" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="EFFECT"> <field name="effectname" value="" fieldtype="LIST" keylist="effects" /> </transition> </transitions> <fields /> </variant> </variants> <keys name="mixerinputs"> <k> </k> <k>CAM1</k> <k>CAM2</k> <k>LIVE1</k> <k>VIZ</k> <k>IN11_HD1</k> <k>IN12_HD2</k> <k>VIZ2</k> <k>ME1</k> <k>ME2</k> <k>LIVE2</k> <k>DUMMY</k> <k>DDR1</k> <k>DDR2</k> </keys> <keys name="effects"> <k>1</k> <k>2</k> <k>3</k> <k>4</k> <k>5</k> <k>6</k> <k>7</k> <k>8</k> <k>9</k> </keys> <keys name="routersources"> <k>R CAM 1</k> </keys> <keys name="routerdestinations"> <k>OPUS 1</k> </keys> </type> </mosarttemplate> </mosPayload> </mosExternalMetadata> </mosObj> <mosObj> <objID>DEMO-0</objID> <objSlug>CAMERA</objSlug> <mosAbstract>CAMERA</mosAbstract> <objGroup>DEMO</objGroup> <objType>STILL</objType> <objTB>50</objTB> <objRev>1</objRev> <objDur>0</objDur> <status>NEW</status> <objAir>NOT READY</objAir> <createdBy> </createdBy> <created>2014-11-11T12:55:05,000Z</created> <changedBy> </changedBy> <changed>2016-05-04T11:01:27,903Z</changed> <description>CAMERA</description> <mosExternalMetadata> <mosScope>PLAYLIST</mosScope> <mosSchema>http://www.mosartmedialab.no/schema/mositem.dtd</mosSchema> <mosPayload> <mosarttemplate> <type name="CAMERA" templateset="DEMO" category=""> <variants fieldtype="LIST" value="1"> <variant name="1"> <transitions value="DEFAULT" enable="false"> <transition name="DEFAULT"> <field name="" value="" fieldtype="TEXT" /> </transition> <transition name="MIX"> <field name="transitionrate" value="0" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="WIPE"> <field name="transitionrate" value="10" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="EFFECT"> <field name="effectname" value="0" fieldtype="LIST" keylist="effects" /> </transition> </transitions> <fields /> </variant> <variant name="2"> <transitions value="DEFAULT" enable="false"> <transition name="DEFAULT"> <field name="" value="" fieldtype="TEXT" /> </transition> <transition name="MIX"> <field name="transitionrate" value="50" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="WIPE"> <field name="transitionrate" value="50" fieldtype="NUMBER" range="0,999" /> </transition> <transition name="EFFECT"> <field name="effectname" value="0" fieldtype="LIST" keylist="effects" /> </transition> </transitions> <fields /> </variant> </variants> <keys name="mixerinputs"> <k> </k> <k>CAM1</k> <k>CAM2</k> <k>LIVE1</k> <k>VIZ</k> <k>IN11_HD1</k> <k>IN12_HD2</k> <k>VIZ2</k> <k>ME1</k> <k>ME2</k> <k>LIVE2</k> <k>DUMMY</k> <k>DDR1</k> <k>DDR2</k> </keys> <keys name="effects"> <k>1</k> <k>2</k> <k>3</k> <k>4</k> <k>5</k> <k>6</k> <k>7</k> <k>8</k> <k>9</k> </keys> <keys name="routersources"> <k>R CAM 1</k> </keys> <keys name="routerdestinations"> <k>OPUS 1</k> </keys> </type> </mosarttemplate> </mosPayload> </mosExternalMetadata> </mosObj>
