These are some of the highlights, alongside a vast number of smaller improvements listed in the release notes.
Gaussian Splatting - Reality, Rendered in Real Time
Photorealism used to be a trade-off: weeks of modelling, or "close enough." Gaussian Splatting in Viz Engine removes it. Instead of rebuilding a location, you capture it.
In virtual studios, set extensions and backdrops stop looking rendered and start looking photographed — holding their perspective and parallax under a moving tracked camera. In augmented reality, the payoff is the reverse: AR elements finally share the visual language of the real footage beside them, and the illusion holds.
Capture instead of model. Photoreal by origin. Real time, on air. Capture once, reuse everywhere.
Introducing Maps - Every story happens somewhere
Maps in Viz Engine put the whole planet inside your graphics — live, navigable, and styled like everything else you put to air. Not a still someone ordered this morning. Not a browser bolted onto a texture. A real map, rendered in the scene, that you can fly.
Pick a place and go. The camera dives from orbit to a rooftop in one unbroken move, your graphics stay pinned to the ground beneath it, and the whole thing lights and composites with the rest of your design because it is part of your design.
Get started - Introducing Template Library
Viz Artist now includes a Template Library, available from the Templates tab of the Welcome Screen.
Browse a growing collection of scenes built by Vizrt, download what you need, and use it as a starting point for your own graphics or as a reference for how specific features work.
New Logicmaker
Build, preview and check complex Transition Logic pages right inside Viz Artist, in a fast native panel connected directly to the engine.
Layers and states at your fingertips. Click a state to take it animated,
A live state graph. Takes run along the arrows for the real transition duration.
Scenes at a glance. Thumbnails, layer filters and search, with warnings on scenes whose Control Object doesn't match.
Guided setup. A wizard builds the master and leaf scenes from scratch for you.
Health checks and safer edits. Checks explain each problem in plain language and assist in fixing issues
Viz Engine
Integrations
  • Realtime Maps rendering
  • Gaussian Splatting Rendering
  • Gradient Editor
  • Security Upgrades
  • More modern User Interface
  • Welcome Screen and Template Library
  • New Logicmaker
  • Pools Inspector
  • Workspace Manager
  • Quick Look
  • New Treeview Search
  • Unreal Engine 5.7 and 5.8 support
  • NDI HX support
