General Description
From a pure Viz Engine viewpoint, the main standards we have to deal with are SMPTE ST 2110-20 (video), -30 (audio) and -40 (ancillary data) as well as SMPTE ST 2059-2 (synchronization profile). Those elements are transported in the essence network. If NMOS is also part of the infrastructure, a separate management network might be available. In addition to the standards mentioned before, other IT infrastructure elements, like DNS and DHCP, could be available.
A typical SMPTE ST 2110 network consists of various endpoint devices connected to one or more switches. The switches might be arranged in a spine-leaf architecture, with high bandwidth backbone switches and lower bandwidth leaf switches where the devices connect to. Additionally, one or more PTP clocks are required for synchronization. Having DHCP and/or DNS servers running in your network could increase manageability.
In NMOS controlled networks, an RDS and a Network Orchestrator/Controller might be part of the infrastructure as well, although not all NMOS Controllers need a registration server, as they are sending RESTful calls directly to the devices.
Unlike SDI (Serial Digital Interface), which carries video, audio,
and ancillary data as a single multiplexed signal over coaxial cable, ST 2110
separates each media essence into independent IP flows:
  • Video — transported as uncompressed RTP streams
  • Audio — transported independently from video
  • Ancillary data — metadata, subtitles, timecode, etc.
This separation allows each essence to be routed, processed, and switched independently, enabling flexible and scalable broadcast infrastructures.
A typical ST 2110 network consists of:
  • Endpoint devices (Viz Engine, cameras, switchers, etc.) connected to switches
  • Switches — often arranged in a spine-leaf architecture:
    • Leaf switches: where devices connect (lower bandwidth)
    • Spine switches: backbone interconnects (high bandwidth)
  • PTP grandmaster clocks for synchronization
  • Optionally: DHCP, DNS, and NMOS servers for management
There are typically two distinct network segments:
Network
Purpose
Essence network
Carries the actual media flows (video, audio, ancillary)
Management network
Carries NMOS control traffic, PTP (if out-of-band), DNS, DHCP
 Multicast and IGMP
ST 2110 flows use IP multicast. Receivers subscribe to multicast groups using IGMP (Internet Group Management Protocol). The network switch must be configured to support IGMP snooping to avoid flooding all ports with all flows.
  • IGMPv2 — basic join/leave
  • IGMPv3 — adds source-specific multicast (SSM) filtering
Synchronization (PTP)
All devices in a ST 2110 network must be synchronized to a common clock using PTP (Precision Time Protocol), specifically the SMPTE ST 2059-2 profile.
Key concepts:
  • PTP Grandmaster — the authoritative clock source
  • BMCA (Best Master Clock Algorithm) — determines which clock becomes grandmaster
  • Clock Domain — a logical grouping; all devices in the same domain sync together
  • In-band PTP — PTP traffic shares the essence network
  • Out-of-band PTP — PTP traffic uses a separate management network
The Matrox video boards in Viz Engine connect to PTP via their SFP ports. The PTP settings (domain number, delay mechanism, IP mode) are configured in ipconfig.xml.
Standards
SMPTE ST 2110
Standard
Definition
2110-20
Uncompressed video flows.
2110-21
Defines traffic shaping and delivery timing. Defines terms like Narrow Sender/Receiver and Wide Sender/Receiver.
2110-22
Constant Bit-Rate Compressed video flows.
2110-30
Uncompressed audio flows.
2110-31
Compressed audio flows according to AES3.
2110-40
Ancillary data flows.
2110-41
Fast metadata flows (WIP).
2059-2
PTP synchronization profile for broadcast media
Redundancy (ST 2022-7)
ST 2110 supports seamless redundancy via ST 2022-7, where each flow is sent on two independent paths. If one path fails, the receiver reconstructs from the other.
Enabled per-output in ipconfig.xml via the Redundancy setting.
AMWA NMOS
Id
Name
Description
IS-04
Discovery & Registration
Allows control and monitoring applications to find the resources on a network.
IS-05
Device Connection Management
Provides a transport-independent way of connecting Media Nodes.
IS-06
Network Control
Lets broadcast control applications manage what happens on the network itself.
IS-07
Event & Tally
Provides an IP-friendly mechanism to carry time-sensitive information, like tally or event data. Is similar to GPIO in a traditional broadcast environment.
IS-08
Audio Channel Mapping
Allows channel-level operations within NMOS environments like channel muting, language swapping,...
IS-09
System Parameters
Allows an NMOS Node to obtain global configuration parameters that are common across the system.
IS-10
Authorization
Allows an API server to accept or reject requests depending on what a client is authorized to do.
IS-11
Sink Metadata Processing
Provides information about physical devices called Sinks associated with Receivers. Allows to configure media parameters of Senders based on information about Sinks.
MS-04
ID & Timing Model
Documents a model for identity and timing that applies to AMWA NMOS specifications that apply to content
MS-05-01
NMOS Control Architecture Framework
Defines a system for modelling various types of devices which interrelates with existing NMOS Specifications and the JT-NM Reference Architecture.
BCP-002-01
Natural Grouping
Documents best practice and recommendations for how to indicate and handle “Natural Groups” of Resources in AMWA NMOS APIs.
BCP-003-01
Secure Communications in NMOS Systems
Documents best practice for using secure transport for NMOS API communications.
BCP-003-02
Authorization in NMOS Systems
Documents best practice for an API server to accept or reject requests depending on what a client is authorized to do.
BCP-003-03
Certificate Provisioning in NMOS Systems
Documents best practice for automated provisioning of TLS Server Certificates to NMOS APIs.
BCP-004-01
Receiver Capabilities
Allows an IS-04 Receiver to express parametric constraints on the types of streams that it is capable of consuming.
BCP-005-01
EDID to Receiver Capabilities Mapping
Provides a scheme and guidelines for expressing EDID information via Receiver Capabilities.
See Networked Media Open Specifications for more details.
Viz Engine Configuration
All IP-related settings are stored in:
%ProgramData%\\Vizrt\\VizEngine\\ipconfig.xml
 Never delete XML tags — only edit values between tags.
Never change `name` attributes (e.g. `<SFP name="SFP A">`).
SFP Settings (per port)
  • IPv4Address, IPv4Netmask, IPv4Gateway — static PTP address
  • DhcpEnable — X.mio5 only; enables DHCP for PTP
  • MasterClockDomainNumber — must match your PTP grandmaster
  • JoinType — IGMP version (2=IGMPv2, 3=IGMPv3)
  • DelayMechanism — EndToEnd (1) or PeerToPeer (2)
Flow Settings (per input/output)
  • EnableFlow — enables the flow at startup
  • DstAddress / DstUdpPort — multicast destination
  • SrcUdpPort — source port (outputs only)
  • AudioPacketDuration — 125µs (1) or 1ms (4)
On X.mio5, each SFP has two separate MAC addresses and requires two IP addresses: one for PTP (in ipconfig.xml) and one for the Windows NIC.
Definition of Terms
Term
Definition/Explanation
SMPTE ST 2110
A series of specifications covering various aspects of transporting media content over IP, as well as describing the related infrastructure topics.
AMWA NMOS
Advanced Media Workflow Association Networked Media Open Specification
A family of specifications that enable interoperability between media devices on an IP infrastructure.​
IGMP
The Internet Group Management Protocol is a communication protocol used by hosts and adjacent routers on IPv4 networks to establish multicast group memberships. It is an integral part of IP multicast and allows the network to direct multicast transmissions only to hosts that have requested them.
SDP
The Session Description Protocol is a format for describing multimedia communication sessions. NMOS IS-05 uses the SDP to describe the content and format of the sender flow, to which a receiver should connect to.
SFP
A Small Form-Factor Pluggable is a compact, hot-pluggable network interface module used together with a Fiber-Optics cable to connect SMPTE ST 2110 devices to a switch.
AOC
Active Optical Cable have the optical electronics already connected, eliminating the connectors between the cable and the optical module.
DAC
Direct Attach Copper use twin-axial copper cables directly attached to the SFP.
FEC
Forward Error Correction is a technique used for controlling errors in data transmission.
PTP
Precision Time Protocol is a protocol used to synchronize clocks throughout a computer network. For broadcast media systems the PTP profile defined in SMPTE 2059-2 is required.
BMCA
The Best Master Clock Algorithm is a method to determine the best clock based on a series of properties.
In-Band
Describes the method to send management data on the same network as the media data.
Out-of-Band
Describes the method to send management data over a network separated from the media data network.
DHCP
The Dynamic Host Configuration Protocol is a network management protocol used for automatically assigning IP addresses.
DNS
The Domain Name System is a hierarchical and decentralized naming system for computers, services, or other resources connected to the network.
DNS-SD
DNS-based Service Discovery allows clients to discover a named list of service instances and to resolve those services to hostnames using standard DNS queries.
RDS
A Registration & Discovery Server is used to register Nodes, Devices, Senders and Receivers in a centralized place using NMOS IS-04.
SDN
Software-defined networking technology is an approach to network management that enables dynamic and efficient configuration.
REST
Representational state transfer defines a set of constraints for how the architecture of a big network infrastructure should behave.
A web API that obeys the REST constraints is informally described as RESTful and is typically loosely based on HTTP methods to access resources via URL-encoded parameters and the use of JSON or XML to transmit data.
NIC
A Network Interface Controller is a computer hardware component that connects a computer to a computer network.
MAC address
A Media Access Control address is a unique identifier assigned to a NIC for use as a network address in communications within a network segment.
SFP and Cabling
Type
Description
SFP
Small Form-Factor Pluggable — hot-pluggable optical transceiver
AOC
Active Optical Cable — integrated optics, no separate SFP
DAC
Direct Attach Copper — twin-axial copper, short reach
Both sides of a connection must use SFPs with the same nominal transfer rate and range classification (Short Reach / Long Reach).
