The Emergency Alert System (EAS) is a national warning system used in the United States that supersedes the Emergency Broadcast System (EBS) and the CONELRAD System. EAS is jointly coordinated by the Federal Communications Commission (FCC), Federal Emergency Management Agency (FEMA) and the National Weather Service (NWS). The official EAS is designed to enable the President of the United States to speak to the citizens of the United States within ten minutes.
In Viz Engine, alert audio can be inserted live from a Windows recording device, such as a microphone or a line input. Viz Engine records from the Windows default recording device. When the alert starts, its audio fades in and is mixed into the EAS output channels. When the alert stops, the audio fades out and Viz Engine releases the recording device.
Starting the alert does not mute the program audio. The alert audio is mixed on top of it, after master volume and mute are applied, so the alert is heard even while the program audio is muted. Mute other audio from the control application if it must not be heard during the alert.
If the recording device is lost during an alert, the alert audio stops. Viz Engine does not switch to a different recording device.
The behavior is supported with the Text-to-Speech plug-in, as well as audio clips which are recorded prior to sending. These clips can be added dynamically. Viz Engine then adds them directly into predefined audio channels and also mute the other channels.
To Specify Output Channels for EAS
Open Audio Settings and select the Channels tab.
In the Out Channel list, enter the keywords
EAS0andEAS1for the left and right channels, respectively. If either keyword is used in any channel, explicit mapping is used.
Several output channels may be pointed to by the same EAS channel. If no explicit mapping is set, Viz Engine defaults to output channels zero and one. Empty mapping is not allowed for the EAS system.
EAS Commands
MAIN*AUDIO*EAS_SYSTEM START: Opens the recording device and fades the alert audio in. Returns an error if no recording device is available. Does nothing if the alert is already running.MAIN*AUDIO*EAS_SYSTEM STOP: Fades the alert audio out and releases the recording device.MAIN*AUDIO*EAS_SYSTEM DELAY <frames>: Sets how many audio sample frames the alert audio stays behind the recording device (48000 frames is one second). By default, the alert starts half a second (24000 frames) behind the recording device. Values are limited to 960 to 46080 frames. Negative values are ignored.
