Slot/Card Configuration
Slot | Usage |
Slot 1 - Gen5 x16 | Graphics Card (single Slot only) |
Slot 2 - Gen5 x16 or x8 | Matrox Video Card (X.mio3, X.mio5, DSX LE4) |
Slot 3 - Gen5 x8 | Other Expansion Card (Serial, GPI) |
Information: Matrox AES Audio can not be installed. Larger Graphic cards will not run in Power redundant mode and are not tested by Vizrt.
Default Hardware
Single CPU 10-Cores
Dual redundant Power
Supply 675W Platinum redundant, hot-swap
PCIe Gen5 Slots
Three PCIe Slots
64GB DDR5
1x 512GB M.2 (Front) + 1x 1TB M.2 (internal)
1x Gbit RJ45 onboard
1x 10Gbit RJ45 Flex IO Slot
OS Support:
Windows 10 LTSC 2021
Windows 11 LTSC 2024
GPU Support:
A4000
4000 Ada
Bios Settings
Security/Secure Boot Configuration Secure Boot: Enable
Advanced/Built-In Device Options:
Increase PCIe Idle Fan Speed(%): 30
Advanced/Power Management Options:
Hardware P-States: Disable
S4/S5 Maximum Power Savings: Disable
PCI Express Power Management: Disable
Advanced/Performance Options:
Workload Configuration: I/O-Focused
Advanced/Power Supply Options:
Power Supply Mode: Redundant
