Types of VANC Data
Two types of VANC data can be extracted and written to shared memory pipes for further use.
Closed Captions: CC data embedded in the VANC data as per SMPTE ST 291M if they are written which the specified DID 0x61.
Custom data: Extraction of data within the user-defined areas as defined in the SMPTE ST 291M - Type1 DID 0xC0 - 0xCF and Type2 DID 0x50 - 0x5F.
The current implementation is limited to the extraction of data based on the NBA Tissot Timer (NTT) protocol by Swiss Timing LTD.
All data is updated once per video unit (field or frame).
Configuration
For data to be extracted, Matrox.CCExtraction = 1 must be set either directly in the configuration file or by setting the value in the Matrox General Section of the Configuration GUI. Additionally, VBI must be enabled on all related input and output channels. As VBI can only be handled from one input, the correct one must be selected in the Scene Settings.
Shared Memory Locations
Closed Caption
CC data is stored in five different shared memory keys:
Cea708_String1Cea708_String2Cea708_String3Cea708_String4Cea708_NumLines
The _String values hold the closed captions itself and _NumLines defines how many of those are actually valid.
NTT Data
The valid data is stored in the shared memory key NTT_Message as plain string and needs to be interpreted according to the protocol specification.
