Slot/Card Installation
Default Hardware
  • Single CPU 16-Cores AMD EPYC 9124 3GHz​
  • Dual Redundant Power Supplies, hot swap ​(220V ONLY! 1800W C13 connector​)
  • PCIe Gen4 + Gen5 Slots​
  • 6 PCIe Slots + 2 Slots for Double Wide GPU​
  • 64GB DDR5 (4x 16GB) up to 12x 16GB​
  • 2x 920GB U.2 Front Mount Hot Swap​
  • 4x Gbit RJ45 onboard in OCP Slot​
  • GPU Support:
    • A2000
    • A4000
    • A6000 ​
    • Virtualized with ESXi:
      • A40
      • A6000
  • OS Support:
    • Windows 10 LTSC 2021
    • Win Server 2022
    • ESXi
Slot Configuration
Slot
Usage
Slot 1
Unused or used by Dual Slot GPU
Slot 2 Gen5 x16
First Graphics Card (with Monitor)
Slot 3 Gen4 x16
Raid Controller
Slot 4
Slot 5 Gen5 x16
Second Graphics Card (no Monitor)
Slot 6 Gen4 x16
Other Expansion Card (Serial, GPI)
Slot 7 Gen5 x16
Matrox Video Card (X.mio5), Matrox M264 or other Expansion Card (Serial, GPI)
Slot 8 Gen5 x16
Matrox Video Card (X.mio3, DSX LE4), Matrox M264 or other Expansion Card (Serial, GPI)
Bios Settings
  • System Settings / Devices and I/O Ports
    • Active Video: Add-in Device
  • System Settings / Enable/Disable Onboard Devices
    • Onboard Video: Disabled
  • System Settings / Operating Modes
    • Choose Operating Mode: Maximum Performance
  • System Settings / Power
    • PCIe Power Brake: Disabled
