Matrox X.mio3 IP / DSX LE 4 IP
The Matrox X.mio3 IP video board was designed to help broadcast equipment manufacturers meet the challenges of the SDI to IP transition. It is a half-height, half-length PCIe card that offers multi-channel video I/O over 10 GbE with IP encapsulation of HD and 3G video. The card offers a total of four IP inputs and four IP outputs. The stream content conforms either to the SMPTE 2022-6 or the SMPTE ST 2110 specification. SMPTE ST 2022-7 is supported in both modes.
DSX LE 4 IP cards have the same capabilities as their X.mio3 counterparts, but lack an onboard video mixer, so DVE is not usable on those boards. Whenever X.mio3 IP is mentioned in this document, the same is true for DSX LE 4 IP.
images/download/attachments/62199100/Xmio3_IP.jpg
The card contains two enhanced small form-factor pluggable (SFP+) slots, or "bays". In the lower bay is SFP A, and hosts input and output channels 1 through 4. The upper bay houses SFP B, which hosts all of the redundant channels used with SMPTE ST 2022-7. The board does not have any SDI inputs or outputs. There is one Mini-BNC connector used to connect the card to the house genlock signal. However, the card can also be locked to a SMPTE ST 2059 conform time signal, sent via the SFPs.
Be aware that SFPs come in two flavors:
  • Short range (SR, 850 nm), and
  • Long range (LR, 1310 nm).
In general, a cable may only connect two SFPs of the same type. In addition, please be aware that the SFP should not be constantly switched in and out of the X.mio3 IP card, as the warranty on the card may be voided if this occurs more than 40 times.
Key Features
  • Dual SFP+ cages for a total of four video inputs and four video outputs
  • IP (SMPTE ST 2059 PTP) and analog blackburst timing reference
  • Guaranteed non-bursty packet transmission
  • Onboard multi-channel Up/Down/Cross scaler
  • Onboard multi-layer compositor
Matrox X.mio3 IP Configuration and IP Properties
The main video properties of the IP input channels are very similar to live input channels on a Matrox card. These properties are accessible in the Video Input: Live Input section of Viz Configuration.
Fill and Key Channel Mapping
When an output channel uses the alpha channel, a key channel is created. This is always the next numbered output channel:
  • Fill is on output 1, and key is on output 2.
  • Fill is on output 3, and key is on output 4.
    Note: It is possible for a dual channel setup to use independent output channels on one SFP, for example 1 and 2. In this case, the Use alpha property must be disabled for both channels.
Default IP Properties
The default IP configuration is meant to serve as placeholder only. It is required to change those default values to match your internal IP landscape. All IP related settings were moved to a separate configuration file. To get the file, Viz Engine must be started at least once. After that, the configuration can be changed using the commands mentioned below, or by editing the file ipconfig.xml, located in the ProgramData directory of Viz Engine. The manual step is necessary for all settings not linked to a command. Please refer to the section below for further information.
Configuration Settings
The configuration of the IP settings was moved to an XML file containing IP relevant parameters only.
Note: When editing the XML file, do not delete any tags and only edit values between <tag> and </tag>.
SFP Settings
Setting
Description
IPv4Address
Indicates the static IPv4 address.
IPV4Gateway
Indicates the IPv4 Gateway.
IPv4Netmask
Indicates the IPv4 Netmask.
Smpte2059SfpSettings::TypeOfServiceDSCP
Indicates that the Type of Service (ToS) is Differentiated Service Code Point (DSCP).
Range is [0..63] (6 bits).
Smpte2059SfpSettings::DelayMechanism
Indicates the type of delay mechanism to use for the time server connection.
0 = Invalid
1 = EndToEnd
2 = PeerToPeer
Smpte2059SfpSettings::IpMode
Indicates the type of internet protocol mode to use for the time server connection.
0 = Invalid
1 = Multicast
2 = Unicast
3 = Hybrid
Smpte2059SfpSettings::MasterClockDomainNumber
Indicates the time server clock domain number to use.
Smpte2059SfpSettings::JoinType
Indicates the type of membership request made.
0 = Invalid
1 = None
2 = IGMPv2
3 = IGMPv3
Smpte2059SfpSettings::IgmpV3Settings::FilterType
Only needed when the join type is set to 3 = IGMPv3. Indicates the filter type applied.
0 = Invalid
1 = Inclusion
2 = Exclusion
Smpte2059SfpSettings::IgmpV3Settings::FilterListCount
Indicates the number of IPv4 source addresses in the filter list. Maximum is four.
Indicates the list of IPv4 source addresses to filter separated by commas.
General Output Settings for SMPTE ST 2022-6 and SMPTE ST 2110
Setting
Description
Redundancy
If set to true, enables the redundant stream for seamless reconstruction conforming to SMPTE ST 2022-7.
Video Output Settings for SMPTE ST 2022-6 and SMPTE ST 2110
Setting
Description
RtpPayloadId
For SMPTE ST 2110 only: Indicates the RTP (Real-time Transfer Protocol) payload ID.
TimeToLive
Indicates the time in which packets can be used in seconds. That is, it indicates the packets' Time to live (TTL).
TypeOfServiceDSCP
TypeOfServiceECN
Indicates that the Type of Service (ToS) is Explicit Congestion Notification (ECN).
Range is [0..3] (2 bits).
Primary::SrcUdpPort
Indicates the User Datagram Protocol (UDP) port of the sender (that is, transmitter).
Primary::DstAddress
Indicates the IPv4 address of the destination (that is, receiver). Only used in multicast.
Primary::DstUdpPort
Indicates the UDP port of the destination (that is, receiver).
Secondary::SrcUdpPort
Indicates the redundant stream UDP port of the sender (that is, transmitter).
Secondary::DstAddress
Indicates the redundant stream IPv4 address of the destination (that is, receiver). Only used in multicast.
Secondary::DstUdpPort
Indicates the redundant stream UDP port of the destination (that is, receiver).
Audio Output Settings for SMPTE ST 2110 only
Setting
Description
RtpPayloadId
TimeToLive
TypeOfServiceDSCP
TypeOfServiceECN
AudioPacketDuration
Indicates the outgoing audio packet duration.
1 = 125 µs
4 = 1 ms
All other values are not supported.
Primary::SrcUdpPort
Primary::DstAddress
Primary::DstUdpPort
Ancillary Data Output Settings for SMPTE ST 2110 only
Setting
Description
RtpPayloadId
TimeToLive
TypeOfServiceDSCP
TypeOfServiceECN
SMPTE352Payload
If set to 1, enables SMPTE 352 packets.
Primary::SrcUdpPort
Primary::DstAddress
Primary::DstUdpPort
General Input Settings for SMPTE ST 2022-6 and SMPTE ST 2110
Setting
Description
Redundancy
JoinType
0 = Invalid
1 = None
2 = IGMPv2
3 = IGMPv3
Video Input Settings for SMPTE ST 2022-6 and SMPTE ST 2110
Setting
Description
RtpPayloadId
Primary::DstAddress
Indicates the reception multicast IPv4 address.
Primary::DstUdpPort
Indicates the reception User Datagram Protocol (UDP) port.
Primary::PacketIntervalThreshold
Indicates the threshold for generating the time interval between the IP packets alarm on the video flow.
The range is from 6.4 ns to 419424.0 ns in intervals of 6.4 ns.
Primary::IgmpV3Settings::FilterType
0 = Invalid
1 = Inclusion
2 = Exclusion
Primary::IgmpV3Settings::FilterListCount
Indicates the redundant stream reception multicast IPv4 address.
Indicates the redundant stream reception UDP port.
Secondary::PacketIntervalThreshold
Indicates the threshold for generating the time interval between the IP packets alarm on thevideo flow.
Secondary::IgmpV3Settings::FilterType
0 = Invalid
1 = Inclusion
2 = Exclusion
Secondary::IgmpV3Settings::FilterListCount
Setting
Description
RtpPayloadId
AudioPacketDuration
1 = 125 µs
4 = 1 ms
Primary::DstAddress
Primary::DstUdpPort
Indicates the threshold for generating the time interval between the IP packets alarm on the audio flow.
The range is from 102.4 ns to 6710681.6 ns in intervals of 102.4 ns.
0 = Invalid
1 = Inclusion
2 = Exclusion
0 = Invalid
1 = Inclusion
2 = Exclusion
Setting
Description
RtpPayloadId
Primary::DstAddress
Primary::DstUdpPort
Indicates the threshold for generating the time interval between the IP packets alarm on the ancillary data flow.
The range is from 819.2 ns to 53685452.8 ns in intervals of 819.2 ns.
0 = Invalid
1 = Inclusion
2 = Exclusion
0 = Invalid
1 = Inclusion
2 = Exclusion
Change IP Properties
Although the IP properties may be changed by editing the configuration file directly, the IP address and port numbers can also be set via the command line interface. Because channel numbering is zero-based here, Output Channel 1 is referred to as VIDEOOUT_0. To check the currently configured values call the command using GET (instead of SET) without parameters.
To Change/Check the Destination Address and Port of the Output Channels:
For SMPTE ST 2022-6/-7 and SMPTE ST 2110:
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTADDRESS SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTUDPPORT SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTADDRESS SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTUDPPORT SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTADDRESSAUDIO SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTUDPPORTAUDIO SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTADDRESSAUDIO SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTUDPPORTAUDIO SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTADDRESSANC SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*DSTUDPPORTANC SET xxxxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTADDRESSANC SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*MATROX*VIDEOOUT_x*REDUNDANCYDSTUDPPORTANC SET xxxxx
To Change the Source Address of the Input Channels:
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*DSTADDRESS SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*DSTUDPPORT SET xxxxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*REDUNDANCYDSTADDRESS SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*REDUNDANCYDSTUDPPORT SET xxxxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*DSTADDRESSAUDIO SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*DSTUDPPORTAUDIO SET xxxxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*REDUNDANCYDSTADDRESSAUDIO SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*REDUNDANCYDSTUDPPORTAUDIO SET xxxxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*DSTADDRESSANC SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*DSTUDPPORTANC SET xxxxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*REDUNDANCYDSTADDRESSANC SET xxx.xxx.xxx.xxx
MAIN*CONFIGURATION*CHANNELS*LIVEIN_x*REDUNDANCYDSTUDPPORTANC SET xxxxx
X.mio3 IP Command Examples
Set the source address of input channel 4. Because channel numbering is zero-based here, IP Input Channel 4 is referred to as LIVEIN_3.
MAIN*CONFIGURATION*CHANNELS*LIVEIN_3*DSTADDRESS SET 224.10.10.34
Set the source UPD port of input channel 4:
MAIN*CONFIGURATION*CHANNELS*LIVEIN_3*DSTUDPPORT SET 9004
Query the destination properties of output 1, fill
> MAIN*CONFIGURATION*MATROX*VIDEOOUT_0*DSTADDRESS GET
< 224.10.10.102
> MAIN*CONFIGURATION*MATROX*VIDEOOUT_0*DSTUDPPORT GET
< 20000
Query the destination properties of the key channel associated with output 1:
> MAIN*CONFIGURATION*MATROX*VIDEOOUT_1*DSTADDRESS GET
< 224.10.10.104
> MAIN*CONFIGURATION*MATROX*VIDEOOUT_1*DSTUDPPORT GET
< 20000
