Matrox M264 S1/S2/S3/S4
Matrox M264 cards feature hardware-based H.264 encoding and decoding capabilities. Depending on the card used, up to three UHD XAVC streams can be encoded/decoded simultaneously. Viz Engine and Channel Recorder are capable of using the M264 cards for playback and capture of XAVC material, without affecting CPU performance.
images/download/attachments/72108796/M264.jpg
Key Features
  • PCI Express Cards
  • H.264 video encoding and decoding
  • UHD resolution support
  • 4:2:2 10-bit
  • 4:2.0 8-bit
  • Sony XAVC compliant encoding including 4K XAVC Long and 4K Intra Class 300/480
  • Panasonic AVC-Ultra compliant
Performance for 4:2:2 10-bit Streams for M264
Resolutions
Structure
Format
Number of streams
M264
M264 S2
M264 S3
M264 S4
2160p
I-frame
XAVC Class 300 & Class 480 / AVC-Intra 4K
1
2
3
4
1080p
I-frame
XAVC Class 200 / AVC-Intra 200
3
6
9
12
1080i
I-frame
XAVC Class 100 / AVC-Intra 100
10
20
30
40
2160p
Long GOP
Generic / XAVC 4K Long
1
2
3
4
1080p
Long GOP
Generic / XAVC Long50 / AVC-LongG50
5
10
15
20
1080i
Long GOP
Generic / XAVC Long25 / AVC-LongG25
10
20
30
40
720p
Long GOP
10
20
30
40
Info: The values above list the theoretical number of streams accelerated by the hardware. This does NOT state that a Viz Engine is able to process the same number as a lot of other factors influence the performance like Disc Speed, IO performance, Transfer Rates etc.
M264 Configuration
Viz Engine
To enable Viz Engine to use M264 cards, the serial number of the M264 needs to be added to the configuration file after the serial number of the installed X.mio3 or DSX LE 4 card.
Matrox.Devices = A123456,A654321
Note: GPU Direct currently is not supported in combination with M264 hardware.
Channel Recorder
Channel Recorder detects any installed M264 card automatically and uses it for encoding, when the XAVC UHD codec is used. No further configuration is necessary.
