Dell R7920
images/download/attachments/50616165/R7920-Bezel.png
Dell R7920 Rack Workstation Slots
images/download/attachments/50616165/dell_r7920_slots.png
Slot
Usage
Slot 1 – PCIe3 x8
Graphics Card only! (Single / Dual Slot)
Slot 2 – PCIe3 x8
Used if a Dual-Slot Graphics Card is installed
Matrox AES Audio
Slot 3 – PCIe3 x8
Video Card (i.e. Matrox Video Board)
Slot 4 – PCIe3 x16
Expansion Cards:
Matrox AES Audio
Blue Storm
SeaLevel
Slot 5 – PCIe3 x8
Video Card (i.e. Matrox Video Board) (if two Graphics Cards are installed)
Slot 6 – PCIe3 M2 SSD
PCIe M.2 SSD
Slot 7 – PCIe3 x8
Slot 7 – PCIe3 x8
Second Graphics Card
Note: Only Matrox boards have been tested.
BIOS Settings
  • During Post, press F2 to get access to the BIOS Setup.
    • Click on System BIOS.
    • Click on Processor Settings.
    • Set Logical Processor to DISABLED.
    • Press ESC to Exit Menu.
  • Click on SATA Settings.
    • Set Embedded SATA to RAID MODE.
  • Click on NVMe Settings.
    • Set NVMe Mode to NonRAID.
  • Click on Boot Settings.
    • Check if Boot Mode set to UEFI.
  • Click on Integrated Devices.
    • Set Embedded Video Controller to DISABLED.
  • Click on System Profile Settings.
    • Set System Profile to Performance.
    • Press ESC twice, Settings are saved.
  • Exit Bios.
  • Press F2 to access BIOS.
  • Change Boot Order (C should be at top).
  • Save Changes and Exit.
Note: Only newer Matrox Boards like xMio3 and DSX.LE4 are supported with Dell R7920 workstations. Older videoboards are not tested by Vizrt.
Note: Certain third party vendor drivers require secure boot to be disabled to install properly.
