Monitoring Takes and Channel Branding
Channel Branding Client
Channel Deck
Channel Deck displays the contents of a playlist.
Number
Description
1
NDI player stream
2
Display name (set during connection)
The Display name component is a button that can toggle error and warning messages if there are any
3
Playlist that presents a list of primary events
4
Primary event
5
Primary event description
6
Primary event planned take time
7
List of secondary events
Each event shows:
  • Planned take time in relation to the primary planned take time (see item 6)
  • Secondary event description
ON AIR Status
Image of a primary event header
When a take is started, the timer on the right side of the primary event header switches to "ON AIR", indicating that the primary is now in progress.
The progress bar tracks how much of a primary event has been completed, and how much is left.
Monitoring Errors and Warnings
Errors present in the Channel Branding Client will be directly reflected in Channel Deck.
Two levels should be taken into account:
Type
Color
Description
 Error
When a channel view and a primary event have red borders, an error is present in a primary that is currently being played out and needs to be addressed urgently.
Warning
When a channel view and a primary event have yellow borders, it means that primaries that are planned for take or have been played out, contain errors and should be addressed before a take.
Three example images of primaries with errors and warnings:
  1. An ON AIR primary, and a planned take of a primary in a warning state with a warning message "Timecode is missing"
    The "Display name" can be pressed to present or hide the error/warning log
  2. An ON AIR primary in error state
  3. Primary finishes its take and the error returns to a warning
