Edits global settings.
Cache Time must be an integer value higher then 0 and cannot be set null.
Syntax
PUT /config/globalsettingsRequest
PUT /config/globalsettings HTTP/1.1Content-Type: application/vizrt.promoserver+xml; type=globalSettingsList <promoserver:globalSettingsList xmlns:promoserver="http://www.vizrt.com/promoserver">  <promoserver:cacheTime>5</promoserver:cacheTime>  <promoserver:machineAddressesCacheTime>60</promoserver:machineAddressesCacheTime></promoserver:globalSettingsList>Response - Successfully edited Global Settings
HTTP/1.1 200 OKContent-Type: application/vizrt.promoserver+xml; type=globalSettingsList  <promoserver:globalSettingsList xmlns:promoserver="http://www.vizrt.com/promoserver">  <promoserver:refLink rel="self" type="application/vizrt.promoserver+xml; type=globalSettingsList" href="http://localhost:9980/config/globalsettings" />  <promoserver:refLink rel="edit" type="application/vizrt.promoserver+xml; type=globalSettingsList" href="http://localhost:9980/config/globalsettings" />  <promoserver:cacheTime>5</promoserver:cacheTime>  <promoserver:machineAddressesCacheTime>60</promoserver:machineAddressesCacheTime></promoserver:globalSettingsList>Error Response - Invalid cache time
HTTP/1.1 400 Bad RequestContent-Type: application/xml; charset=utf-8<string xmlns="http://schemas.microsoft.com/2003/10/Serialization/">Input content can't be used to update global settings: Cache time for machine addresses must have an integer value</string>
