Get all templates for a channel's template pool.
Syntax
GET /api/channels/[channel]/templatesRequest
GET /api/channels/test/templates HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.integrationshubv2+xml; type=list <?xml version="1.0" encoding="utf-8"?><inthub:list xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="inthub:masterTemplateList" xmlns:inthub="http://www.vizrt.com/integrationshub">    <inthub:masterTemplate>        <inthub:name>1000</inthub:name>        <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=mastertemplate" href="http://localhost:9991/api/channels/test/templates/1000" />        <inthub:concept>HD</inthub:concept>        <inthub:updated>2021-12-10T23:04:53Z</inthub:updated>        <inthub:importDatetime>2021-12-10T23:04:53.918Z</inthub:importDatetime>        <inthub:layer>/ChannelBranding/channels/test/templates/sceneselectors/1000</inthub:layer>    </inthub:masterTemplate>    <inthub:masterTemplate>        <inthub:name>4000_c1_c3</inthub:name>        <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=mastertemplate" href="http://localhost:9991/api/channels/test/templates/4000_c1_c3" />        <inthub:concept>SD</inthub:concept>        <inthub:updated>2023-12-15T12:10:15Z</inthub:updated>        <inthub:importDatetime>2022-06-10T13:01:33.124Z</inthub:importDatetime>         <inthub:layer>/ChannelBranding/channels/test/templates/sceneselectors/4000_c1_c3</inthub:layer>    </inthub:masterTemplate>    <inthub:masterTemplate>        <inthub:name>4000_C1</inthub:name>        <inthub:refLink rel="self" type="application/vizrt.integrationshubv2+xml; type=mastertemplate" href="http://localhost:9991/api/channels/test/templates/4000_C1" />        <inthub:concept>IPHONE</inthub:concept>        <inthub:updated>2023-12-15T12:10:20Z</inthub:updated>        <inthub:importDatetime>2022-06-10T13:05:12.326Z</inthub:importDatetime>          <inthub:layer>/ChannelBranding/channels/test/templates/sceneselectors/4000_C1</inthub:layer>    </inthub:masterTemplate></inthub:list>Disallowed Actions
This end-point does not allow POST, PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
