Returns a list of channel-definitions.
Syntax
GET /config/channelsRequest
GET /config/channels HTTP/1.1Response
HTTP/1.1 200 OKContent-Type: application/vizrt.promoserver+xml; type=channelsList<promoserver:channelsList xmlns:promoserver="http://www.vizrt.com/promoserver">    <promoserver:channelItem>        <promoserver:refLink rel="self" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/Test" />        <promoserver:refLink rel="edit" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/Test" />        <promoserver:refLink rel="machineaddresses" type="application/vizrt.promoserver+xml; type=machineAddressesList" href="http://localhost:9980/config/channels/Test/machineaddresses" />        <promoserver:name>Test</promoserver:name>    </promoserver:channelItem>    <promoserver:channelItem>        <promoserver:refLink rel="self" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/TestCross" />        <promoserver:refLink rel="edit" type="application/vizrt.promoserver+xml; type=channel" href="http://localhost:9980/config/channels/TestCross" />        <promoserver:refLink rel="machineaddresses" type="application/vizrt.promoserver+xml; type=machineAddressesList" href="http://localhost:9980/config/channels/TestCross/machineaddresses" />        <promoserver:name>TestCross</promoserver:name>    </promoserver:channelItem></promoserver:channelsList> Disallowed Actions
This end-point does not allow PUT or DELETE, and will return a 'HTTP/1.1 405 Method Not Allowed'.
