Tonemapping is a technique that converts color values from a high dynamic range (HDR) to a low dynamic range (LDR) a display can output.
The tonemapping shader is directly integrated into the Viz Engine Render Pipeline and is applied as the last step of the main rendering process, just before the image is processed for video output.
To enable the tonemapping post effect, go to the Scene's Rendering Settings and enable Tonemapping under Color Space. Be sure to enable post-processing effects in the Scene Editor to have a preview of it while editing its properties.
There are two available Tonemapping Operators:
  • Neutral
  • Filmic
Neutral (Khronos) Tonemapper
The neutral tonemapper keeps neutral colors up to a certain maximum and only maps highlights into sRGB color space. This allows to keep all neutral colors, but clamps overshooting shadows and highlights.
No tonemapping applied
Filmic Tonemapper
(Note color changes on all spheres)
Neutral Tonemapper
(Note color changes only on outer spheres)
The neutral Tonemapper should be used if your colors match a given Corporate design.
Filmic Tonemapper
The filmic tonemapping operator proposed by John Hable is used.
The order of the adjustments to the input color is:
  • Exposure
  • Saturation
  • Contrast
  • Tonemap
  • Lift/Gamma/Gain
Exposure / Saturation / Contrast
Parameter
Description
exposure
Adjusts the exposure of the input pixels.
saturation
Adjusts the saturation of the input pixels.
contrast
Adjusts the contrast of the input pixels.
Examples
Screenshot
Information
Default Settings
contrast = 1
exposure = 0
saturation = 1
exposure = 0.5
contrast = 1.2
saturation = 0.2
The function that is applied on the HDR input colors can be configured using multiple parameters in the Render Graph node. To see how the operator works check out the interactive graph.
Parameters
Parameter
Description
shoulderStrength
linearStrength
linearAngle
toeStrength
toeNumerator
toeDenomiator
Defines the shape of the curve.
whitePoint
Defines the value in the input that translates to 1 in the output.
All values below are squeezed into the range from 0 to 1, everything above results in values larger than 1.
Examples
Screenshot
Information
Tonemapping Disabled
Tonemapping Enabled
Default values.
Tonemapping Enabled
Adjusted values compared to the default ones, to have a slightly improved saturation.
Color Correction
Color correction is done after tonemapping and applies the so called Lift, Gamma and Gain input values: output = (input * gain + lift) ^ gamma.
The formula being used is mentioned in https://en.wikipedia.org/wiki/ASC_CDL. To see what the separate values do check out the interactive graph.
Parameters
Parameter
Type
Description
gain
Multiplier
Adjusts highlights.
lift
Offset
Adjusts brightness.
gamma
Exponent
Adjusts mid-tones.
Examples
Screenshot
Description
Default Settings
lift = 0
gamma = 1
gain = 1
for red, green and blue channels.
Adjusted lift for red and green channels, leaving blue untouched.
Adjusted gamma for red and green channels, leaving blue untouched.
Adjusted gain for blue channel, leaving red and green channels untouched.
Credits
Environment image is taken from https://hdrihaven.com/hdri/?h=leadenhall_market.
