It is very easy to set up a working 3D environment for a designer to start creating stereoscopic scenes. The demands on the hardware are moderate.
Hardware Requirements
Any workstation
Any NVIDIA Quadro graphics card with a 3-pin DIN connector
NVIDIA 3D vision or equivalent
Monitor with a refresh rate >= 100Hz
Software Requirements
Viz Artist/Engine 3.3 or later
The display must be set to a refresh rate >= 100Hz
Classic Render Pipeline only.
To Set Up a 3D Working Environment
In the Windows video board 3D settings, Set Stereo - Enable to
On.Select the appropriate Stereo - Display mode for each stereo device.
Note: For NVIDIA’s 3D Vision, this is ‘On-board DIN connector’.
In Camera settings (see the Configuring Viz section of the Viz Engine Administrator Guide) set Stereo Mode to Quad Buffered.
Also it is possible to use an autostereoscopic monitor that supports sub-fields or side-fields, such as Miracube’s c190 series. The drawback with these displays is that you need to go On Air to get a full-screen image, which is halved in resolution.
