To open the Scene Settings editor, select the Scene Settings tab in the Property panel. The Scene Settings editor makes it possible to modify the global parameters for the scene. Some of the settings may be disabled as they depend on the chosen Render Pipeline.
There are various types of scene settings. Click the tabs at the side of the Scene Settings editor to open the respective panels:
- Rendering Panel
- Global Settings Panel
- Global Media Assets Settings
- Plug-in Panel
- Clipper Panel
- High Dynamic Range Panel
- Real Time Global Illumination
- Classic SSAO
- Virtual Studio Panel
- Script Panel
- Adaptive Scene Design Formats
- Unreal Scene Settings
Formats Settings
Working with File Collections
