When using the Color Picker of Viz Artist, a correct conversion from Linear to sRGB color space is performed. This should match, no matter if Gamma Correction or Tonemapping effects are active.
Info: The color picker also works across different applications, even if the cross hair disappears when leaving the Viz Artist window.
