Viz Arc is a control application that can be used for one or more Viz Engines, and can also drive Unreal Engine and Flowics render targets. It uses Graphic Hub and its REST API for browsing Scenes, Images, merged Geometries and Materials, and integrates with the wider Vizrt ecosystem: Media Sequencer (MSE) and Viz Pilot / Pilot Data Server for newsroom-driven playout, and Viz One, Media Service and Viz Data Center for media and data.
When working with tracked cameras in a Virtual Studio environment, Viz Arc communicates with Tracking Hub to send and receive camera tracking information. It also offers Virtual Camera Flights for scripted virtual camera moves, an Object Tracker, and works alongside Viz Arena for sports augmented reality.
One of the key features of Viz Arc is the ability to set up Augmented Reality elements in outdoor productions directly over a map. A working internet connection is required to retrieve map imagery from providers such as Bing or OSM. Stage layouts and floor plans can additionally be imported from CAD / DGW / DXF drawings.
Beyond the desktop application, Viz Arc can be operated and automated in many ways — a browser-based Web UI, a REST API, MQTT messaging and timecode (NDI / Plura), as well as physical control surfaces such as Elgato Stream Deck, MIDI devices, Art-Net (DMX) and GPI. Viz Arc also includes a built-in AI assistant (MCP server) that lets you build templates, trigger actions and query the documentation using natural language.
Ports
Application
Port
Protocol
Viz Arc Web Service
Default port: 5004
Default port: 5005
HTTP
HTTPS
Viz Arc REST Service
(standalone service)
Default port: 9004
Default port: 9005
HTTP
HTTPS
Viz Arc MQTT Broker
Default port: 1883
TCP
Vic Arc TCP Server
Default port: 9204
TCP
Viz Arc Template Script
Viz Arc Main Script
Debugging port: 9222
Debugging port: 9223
TCP
TCP
Viz Engine
Default ports: 6100, 6800
Feedback port: 7476
TCP
UDP
Viz Arc Feedback
Feedback port: 12050
UDP
Graphic Hub REST
REST API port: 19398
HTTP
Tracking Hub
Requests data through port: 20000
Receives data through port: 4000
TCP
UDP
Media Sequencer
REST API port: 8580
HTTP
Media Service
for v4.1.0 and higher: 25506
for v2.3.3 and lower: 21099
HTTP
Pilot Data Server
REST API port: 8177
HTTP
Coder
Coder port: 8081
HTTP
Unreal Engine
arcCom port: 5647
TCP
Engine Service
VizArcEngineService port: 5644
TCP
Unreal Web Interface
Default port: 30010
HTTP
Unreal Web Socket
Default port: 30020
TCP
Vinten Automation Server
Vinten port: 11239
TCP
Viz One
REST API port: 80
HTTP
Viz Arena
Web API port: 40055
HTTP
Viz Object Tracker
Default port: 10005
HTTP
Art-Net Integration
Default port: 6454
TCP
Monogram Integration
Default port: 51234
UDP
