Viz Arc integrates to Viz Engine and scenes allowing you to design your virtual studios and augmented reality elements in Viz Artist, eliminating the need for creating custom applications to control virtual studios and augmented reality elements for each production.
A simple user interface allows you to create projects for each production.
Easily configure action buttons that control any property, element or animation in a Vizrt Scene without any programming or expert skills. Operators can access a panel of actions that can be triggered at any time.
Arc is an out-of-the-box solution that eliminates the need to create custom controllers for operating AR/VR elements and non-scripted shows.
Viz Arc lets you easily configure the logic of each individual element and operate virtual studios and augmented reality or graphic elements on a non-scripted live production, while reducing the setup time and expertise required.
Related Documents
Viz Artist User Guide: Contains information on how to install Viz Engine and create graphics scenes in Viz Artist.
Viz Engine Administrator Guide: Contains information on how to install and configure Viz Artist and Engine, and supported hardware.
Viz Graphic Hub Administrator Guide: Contains information needed to configure and operate Graphic Hub.
Viz Tracking Hub Administrator Guide: Contains information required to understand Tracking Hub and Studio Manager, two important software components in the Viz Virtual Studio solution.
Viz Pilot User Guide: Contains information needed to operate Viz Pilot and use the Newsroom Component to create newsroom data elements for a newsroom system playlist.
Feedback and Suggestions
We encourage feedback on our products and documentation. Please contact your local Vizrt customer support team at www.vizrt.com.
Legal
Copyright ©2025 Vizrt. All rights reserved.
Disclaimer
Antivirus Considerations
Real-Time Scanning: Keep it enabled, but exclude any performance-sensitive operations involving Vizrt-specific folders, files, and processes. For example:
C:\Program Files\[Product Name]
C:\ProgramData\[Product Name]
Any custom directory where [Product Name] stores data, and any specific process related to [Product Name].
Risk Acknowledgment: Excluding certain folders/processes may improve performance, but also create an attack vector.
Scan Scheduling: Run full system scans during off-peak hours.
False Positives: If behavior-based detection flags a false positive, mark that executable as a trusted application.
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
