Files and folders that are used or modified by Viz Arc are listed below.
Depending on the logged user, related files and folders can be found under %localappdata%\vizrt\VizArc. When the user has administrative privileges, the location is c:\ProgramData\vizrt\VizArc\.
The read-only folder can be seen in the General Configuration Settings, based on the logged user launching Viz Arc.
The first time a non-administrative user launches Viz Arc, the config and profile settings are copied from c:\ProgramData\vizrt\VizArc\, to the local application data folder. This way, an administrator can create a global default configuration for all users logging onto the system.
  • config: Contains config.json file with all default and custom Viz Arc configurations.
  • keybinds: Contains keybinds.json file used to determine system keyboard shortcuts.
  • Logs: Contains a text log file containing every log name, date, log level and message since the first launch of the application.
  • profiles: Contains profiles.json file where configured profiles and corresponding Channels and Engines are stored.
  • projects: Contains a sub-folder and .json file for each saved Viz Arc project. You can change project folders in the Settings > Application Settings panel.
  • Resources: Contains useful resources (for example, plug-ins for external devices, Unreal plug-ins and Viz archives).
  • temp: Contains temporary files that are automatically created and deleted in case of a software crash.
