This page covers the current release of the Vizrt Asset Management platform.
VAM 1.0.0
Released 2026-09-08. This is the initial 1.0.0 release of the Vizrt Asset Management platform — its first general-availability release. Every first-party VAM component ships on the aligned 1.0.0 version line.
Component Versions
Component | Version |
VAM core service | 1.0.0 |
Configuration Service (API + GUI) | 1.0.0 |
MCP Server | 1.0.0 |
Workflow Bridge | 1.0.0 |
Deployment Console ( | 1.0.0 |
Configuration Service API contract | 1.9.0 |
Independently-versioned add-ons ship on their own version axes: Viz Pilot Edge (3.7.0), Pilot Change Broadcast Service (1.0.4), PCS (1.0.15), Unified Control (2.0.0) and Meeting Summarizer (1.0.0).
Bundled infrastructure components: SurrealDB 3.2.4, OpenSearch 3.8.0, Traefik 3.7.12.
Platform Capabilities
The capabilities below are the standing feature set of the platform as of this release.
Storage, Versioning & APIs
- Durable core. VAM stores assets in an S3-compatible object store, with a SurrealDB document store and a RabbitMQ event bus behind it.
- Everything is versioned. Every document and blob carries a version identifier, and conditional writes return 412 on a stale ETag so concurrent edits never clobber one another.
- Optional full-text and semantic search through OpenSearch enriches asset discovery when enabled.
- Integrator surfaces. A Schema API lets integrators define and evolve task schemas, and an MCP server exposes the platform to AI agents over the Model Context Protocol.
Editorial Integrations
- Pilot Core Service bridges Viz Pilot to VAM, and the Pilot Change Broadcast Service keeps rundown changes in sync.
Installation & Cluster Topologies
- Three install workflows: online installation, prepare offline installation, and offline installation.
- Supported targets: Hyper-V, VMware vSphere, AWS EC2, or an existing Kubernetes cluster (AWS EKS support is coming soon).
- Replication. Clusters can be paired for active-active replication using a single-use connection code.
- Identity providers. Keycloak is built in; Okta and Auth0 are supported as preview integrations.
- Certificates. Issuer options include Microsoft AD Certificate Services (AD CS), and Trust Roots distributes uploaded root CAs across the cluster.
- Backups & recovery. Schedule, verify and restore backups, up to full disaster recovery onto a new cluster.
- Safe upgrades. Package upgrades are managed in-cluster, and a failed upgrade can be rolled back.
- Auditability. An Audit Log records configuration changes.
