You can use templates for an easy and fast configuration of several studios. There are several pre-made templates available in C:\ProgramData\vizrt\VizTH\. You can also create your own templates. However, you must copy them to the Tracking Hub directory on a new installation.
Using Existing Templates
- Go to Tools > Create System From a Template. - This opens a new window where you can select a predefined template.
- After clicking Create, you get a complete system consisting of at least one Tracking System, one rig and one service. Depending on the template, it can include several Tracking Systems and rigs.
- Configure the individual settings as applicable: - Interface of the tracking system.
- Set the correct COM or UDP port.
- Insert the correct IP address for the Viz Engine.
Creating New Templates
If you want to reuse a complete system, you can create your own template for it.
- Go to Tools > Make Template. - This opens a new window where you can select the parts for your template:
Important: Do not select Parameter in the Services column!
- When you have selected you items, click Create Template and enter a name for the template. Then click Save As. This saves a new template in the C:\ProgramData\vizrt\VizTH\Templates directory, in a file called XML_TH_Temp_your_name.xml.
