The following lists the ports used by Tracking Hub and Studio Manager. Please note that this may be different due to the tracking systems in use.
| Port Number | Protocol | Used for |
| Tracking Hub | ||
 | UDP | Default port for sending tracking data to Viz Engine |
 | UDP | Backup Communication |
 | TCP | Viz Engine Communication |
 | UDP | For example, incoming FreeD protocol |
 | TCP | Lensfile Editor Web Interface |
 | TCP | Command Port |
| Studio Manager | ||
 | UDP | Viz Engine Communication |
 | UDP | Parameter Service Port |
| Other Components | ||
 | TCP, UDP | Codemeter |
| Other Ranges | ||
| > | Used by Tracking Hub | |
| > | Used by Studio Manager | |
