This section details how to configure Viz Virtual Studio.
- Click Open to select a previously saved studio configuration, or create a new configuration by clicking Save As.
- Set the Frequency frame rate. Available options are: - 50 Hz
- 60 Hz
- 59.94 Hz
- 30 Hz
- 29.97 Hz
- 25 Hz
- 24 Hz
- Set the Synchronization base: - Freerun: Does not synchronize. Tracking Hub runs using its own time base, corresponding with the configured frequency. This option should not be used in production environments.
- AV-Card: Synchronizes using Plura PCL-PCI or PCL-PCIe sync cards.
- Viz Engine: Synchronizes with a Viz Engine running on the same computer.
- Go to Configure Topology.
