The following lists the ports used by Tracking Hub and Studio Manager. Please note that this may be different due to the tracking systems in use.
Port Number  | Protocol  | Used for  |
Tracking Hub  | ||
  | UDP  | Default port for sending tracking data to Viz Engine  |
  | UDP  | Backup Communication  |
  | TCP  | Viz Engine Communication  |
  | UDP  | For example, incoming FreeD protocol  |
  | TCP  | Lensfile Editor Web Interface  |
  | TCP  | Command Port  |
Studio Manager  | ||
  | UDP  | Viz Engine Communication  |
  | UDP  | Parameter Service Port  |
Other Components  | ||
  | TCP, UDP  | Codemeter  |
Other Ranges  | ||
>  | Used by Tracking Hub  | |
>  | Used by Studio Manager  | |
