This page lists available keyboard shortcuts in Template Builder.
Shortcut
Description
CTRL + O
Open the Open Template dialog where you can select a template to open.
CTRL + S
Save a template.
CTRL + Z
Undo.
CTRL + Y
Redo.
F5
Run or stop the template script in Design mode.
ALT + R
Switch between Run mode (Run Template) and Design mode (Back to Design).
ESC
Leave Run mode (Back to Design).
CTRL + C / CTRL + V
Copy and paste the selected fields and UI items of a custom tab, in layout edit mode.
Warning: The shortcut CTRL + O does not work properly in Firefox version 65.0.1 and later.
Graphics Preview Player Shortcuts
Use the following shortcuts for the Graphics Preview player:
Shortcut
Description
SPACE or CTRL + SPACE
Play/pause.
SHIFT + I
Go to the in-point.
SHIFT + O
Go to the out-point.
, (comma)
Move one frame back.
. (period)
Move one frame forward.
