Supported Viz Artist Control Plugins
Plugin Name | Comments |
Control Chart | The Control Chart plug-in exposes control of chart data from the Visual Data Tools plugins. |
Control Text | From Viz Engine 5.0.1 and above, Control Text exposes text from both the Classic and Viz Engine renderer pipeline. |
Control Geom | The Control Geom plug-in exposes the control of geometry objects to the user. |
Control Image | The Control Image plug-in creates an image control in the control clients. |
Control List | The Control List plug-in allows you to create table controls. Normally there should be a Control Object for each row. |
Control Material | The Control Material plug-in exposes the material control to the user. Remember to set up a search provider towards Graphic Hub, to use this. |
Control Number | The Control Number plug-in (also known as Control Num) is used to be able to decide how a number input is to be formatted. It can be a value given by the control client user or by any external source. It should be used instead of Control Text when numbers are the input value. |
Control Object | Control Object should always be added to a scene when you add other control plugins. It is in this plugin that you mark if a scene is part of a transition logic set or not. There should normally only be one control object in the scene. The exception is when you use a control list when there is a control object for every line. |
Control OMO | The Control Object Moving (Omo) plug-in gives you the possibility to add a group of containers and reveal one at the time. This control plugin exposes an integer. It is typically nice to use a drop-down for these with proper field names. |
Control Video | The Control Video plug-in exposes control over a video codec channel (ClipChannel). Does not support clips in soft clip players. |
Control WoC | A replacement of the Control Maps plugin with more options and on-the-fly feedback from Viz Artist/Engine. |
Info: If a Control Plugin is not listed in the table above, it is not supported by Graphic Hub and/or Template Builder.
