From version 2.4.0, it is possible to generate traces with Channel Recorder. The generated trace is located in C:\ProgramData\vizrt\ServiceHost\trace.
Supported commands are:
TRACE STARTTRACE STOPTRACE RECORD_FRAMESTRACE RECORD_DURATION(in milliseconds, like Viz Engine)
Trace generation can help identify bottlenecks and, when used in conjunction with logs, serves as a valuable tool for troubleshooting.
