Hardware Requirements
The Viz Engine Administrator Guide provides a detailed description of these machines.
Note: To be able to achieve maximum performance using Channel Recorder, Hyperthreading should be enabled. This is located in the BIOS.
Channel Recorder requires one of the following video boards:
Video Boards | Recording Capability |
Matrox X.mio3 | SDI |
Matrox DSX LE4 | SDI |
Matrox X.mio5 IP | SMPTE ST 2110 |
Matrox X.mio5 X2 | SDI |
Matrox X.mio5 / 8 | SDI |
Matrox DSX LE5 / 4 | SDI |
Matrox DSX LE5 / 8 | SDI |
Matrox M264 | RTP/H.264 |
DSX.Core (1) | RTP/H.264 |
(1) From Service Host version 2.1.0 and later, DSX.core has a new license mechanism. The CodeMeter server search list must be updated so that the old server license that contained DSX.core licenses is removed from the list. If CodeMeter server search list still has the old server license listed, then Channel Recorder still attempts to use the old license implementation. | |
Note: All the above boards should be upgraded to enable recording with different codecs. To check which upgrades the board has available, use the Matrox Utils in the task bar and check if the board has 500 or 550 upgrade applied (for ProRes). If the board does not have this upgrade, this must be ordered. Additionally, to receive RTP/H.264 the Matrox M.264 must have the RTP upgrade. Refer to Recording RTP/H.264 Stream for more information.
Note: The DSX.core is not technically a physical board and is used to receive and record RTP/H.264 streams. Refer to Recording RTP/H.264 Stream for more information.
Important: This procedure needs to be followed after installing DSX.core:
Unregister mvfDsxCore.dll.
Click Start > Run (or use the Windows command line: Search > CMD > (Right click) Run as Administrator).
Type
REGSVR32 /U "C:\Program Files\Matrox DSX-TopologyUtils\System64\mvfDsxCore.dll"and press ENTER.
Shut down X.info in the task manager.
Delete mvfDsxCore.dll from the folder C:\Program Files\Matrox DSX-TopologyUtils\System64\.
Start X.info.
Note: The M.264 encoder/decoder board is required for CPU intense codecs like XAVC. It is mandatory for UHD recording and strongly recommended for AVC codecs.
To Upgrade Class and Firmware
Important:
When upgrading from 10.4 to 11.x Matrox driver, follow these mandatory steps:
Uninstall old Matrox driver
Cold Boot (Turn off computer for at least 20 seconds)
Switch Computer on
Continue installation of new driver
To upgrade your Matrox board, for example to enable more IO-ports or a codec upgrade for HD recording, you must use the mvDongleUpdater.exe update utility with your Vizrt supplied license upgrade file <filename>.OPT. This utility is installed with the Matrox driver package and is normally installed to C:\Program Files\Matrox DSK.utils\drivers\mvDongleUpdater.exe.
To upgrade the card use this syntax:
C:\Program Files\Matrox DSX.utils\drivers\mvDongleUpdater.exe upgrade -sn="BoardSerialNumber" -f="Path to the upgrade file" The command above must be run from a Windows command line window.
Software Requirements
Channel Recorder with Service Host requires Matrox DSXTopology Utils version11.1.101.2163.
In most cases, a system with a configured and reliable NTP server is necessary. This is particularly important when working with other components such as Viz Dart or Viz One, in which case they should all use the same NTP server. The NTP should be configured so that the polling interval is low enough to not cause noticeable drifting. A value of one minute polling time should be used as a maximum. In Windows, this can be changed using regedit. The important values are located in:
HKEY_LOCAL_MACHINE > SYSTEM > ControlSet001 > services > W32Time > TimeProviders > NtpClient
SpecialPollInterval should be
60.
HKEY_LOCAL_MACHINE > SYSTEM > ControlSet001 > services > W32Time > Config
MaxNegPhaseCorrection should be
0xFFFFFFFF(default value for domain members).MaxPosPhaseCorrection should be
0xFFFFFFFF(default value for dmain members).UpdateInterval should be
100.
More info is available at https://docs.microsoft.com/en-us/windows-server/networking/windows-time-service/windows-time-service-tools-and-settings#Configuration.
