The Spline Path plug-in creates complex paths with an arrow look.
Spline Path Properties
use LOD: Enables/disables dynamic level of detail.
Node: Defines the node index. For example, node 3 or node 25.
X, Y and Z: Sets the 3D point to define a node.
Length: Stretches the entire path in X-direction.
Width: Stretches the entire path in Y-direction.
Threshold: Increase this value if you do not need a high path accuracy but more performance.
Add, Move, Remove and Clear: Add adds a new node with an specific index. Move moves an existing node to another X, Y or Z-point. Remove removes an existing node. Clear clears all nodes.
Mode: The following options are available:
Tube: Renders the entire object.
Band XY: Renders only the front side.
Band XZ: Renders only the top side.
Band YZ: Renders only the left side.
Arrow: Creates an array look.
Arrow Length: Sets the arrow length (only when Arrow is set to
On).Arrow Width: Sets the arrow width (only when Arrow is set to
On).Texture Stretching Mode:
To Create a Spline Path
Create a new group container.
Add the Spline Path plug-in.
Add the Expert plug-in.
Open the Expert editor.
Set Back Face to On.
Add a Material and/or a Texture to the group.
Open the Spline Path editor.
Set Node to
0/ X to50.0/ Y to50.0.Click Add.
Set Node to
1/ X to150.0/ Y to25.0.Click Add.
Set Node to
2/ X to250.0/ Y to10.0.Click Add.
Set Node to
3, X to350.0, Y to45.0.Click Add.
