The Text FX Vertex Color plug-in adds a color per vertex effect to the text.
Supported Pipelines | |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Note: Works only if the text is set to texture (does not work with geometry text).
Text FX Vertex Color Properties
Color Bbox: Defines the reference bounding box, global for the entire text, or local for each character.
Color Direction: Defines the color gradient shape. Available options are; top left to bottom left, top right to bottom right, top left to top right, bottom left to bottom right, top right to bottom left and four corners.
Color Level: Sets the level of the color (
0.1to1.9). Default is1.0.Top and Bottom Left and Right: Sets the color and alpha value for each edge.
Color use Alpha: Enables alpha.
