The Text FX Rotate plug-in allows you to create an effect where the characters rotate on the X-, Y- or Z-axis.
Supported Pipelines | |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Text FX Rotate Properties
Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
Anchor Vertical: Sets the anchor point for the characters on the vertical plane.
Use Axis: Defines on which axis the characters rotate.
Begin: Sets the initial rotated position of the characters.
End: Sets the ending rotated position of the characters.
