The Text FX Jitter Scale plug-in animates a jittering effect on the scale of the character.
Supported Pipelines | |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Text FX Jitter Scale Properties
Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
Anchor vertical: Sets the anchor point for the characters on the vertical plane.
Use Axis: Defines on which axis or axes the characters scale to create the jittering effect.
Lock Axis: Gives all the axes get the same Min, Max and Randomness settings when enabled. If you disable randomness, these parameters are visible for each of the axes and must be set individually.
Min: Sets the minimum scaling for the characters.
Max: Sets the maximum scaling for the characters.
Randomness: Sets the intensity of the jittering movement.
