The P Quad plug-in creates a rectangle with different attributes.
Note: This plug-in is located in: Plugins -> Geom plug-ins -> Primitives
P Quad Properties
Use LOD: Enables/disables dynamic level of detail.
Tesselation: Sets the degree of detail.
Bevel: Sets the radius of rounded edges.
Width: Sets the width of the quad.
Height: Sets the height of the quad.
Corners: Sets the number of the corners for rounded edges.
Use Control Vertices: Allows the four edges of the quad to be moved individually. With the following parameters, edges can be placed in X and Y directions as desired:
LowerLeft X
LowerLeft Y
LowerRight X
LowerRight Y
UpperRight X
UpperRight Y
UpperLeft X
UpperLeft Y
Use Vertexcolors: Allows the color of the edges to be set when enabled. With the following parameters, individual colors can be selected:
UpperLeft
Lower Left
Upper Right
Lower Right
