The Microstructure Shader plug-in simulates a detailed surface structure by bump mapping and lights it with the aid of a highlight.
Additionally, a clear coat layer reflects the surrounding (from a cube map). A normal map is used to define the surface structure.
Supported Pipelines | |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Microstructure Shader Properties
Reflection Multiplier/Exposure: Affects the exposure of the environment map. This is especially helpful when working with HDR images.
Gamma of EnvMaps: Controls the gamma correction of the environment map. This is once again particularly helpful when working with HDR images.
Bump Map / Normal Map: Is the texture that defines the surface structure with encoded normals.
Environment Map: Is a cube map that describes the environmental surrounding used to calculate reflections.
Standard_Bump: Is a technique to be used with geometry that has no standard UV texture coordinates and normals.
Binormal_Bump: Is a technique to be used with geometry having texture coordinates and normals.
Microstructure Shader Best Practices
Apart from the parameters in the plug-in container, it is necessary to assign a material and a texture as a color/basic texture. Do not forget to adjust also the material parameters like ambient, diffuse, specular color and shininess, to achieve the required look for your surface
