The Map Zoom plug-in builds single destination animated scenes. Because the scene is treated as an independent Map Object it can be added into any graphic including Transition Logic scenes.
The map is created as GeoImage (flat map) and adds all necessary plug-ins to the hierarchy.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Maps
Map Zoom Properties
Zoom: Defines the zoom in percent (
0-100%), in order to animate to the final destination.Labels: Takes the size of the label from the original design when set to Fixed. When set to Auto Scale, the size is calculated based on the size of the map.
