DataNodes and DataFields
DataPool is a hierarchical data structure composed of DataFields and nodes. DataFields are the lowest level of the hierarchy. The DataFields don’t have children. Nodes are groups of DataFields. The DataPool hierarchy has a root node. Each of the DataFields in the hierarchy has a parent node, either the root node or any other sub-level node.
Example 1
The following example shows a hierarchy with a root, two nodes (NA and NB) and six DataFields. As can be seen each of the DataFields reside below a node. Setting the value of the DataField FA under the node NA follows the hierarchical structure to the required DataField: NA/FA=<some information>;
In the case of field FC under NB: NB/FC=<some other information>;
To set the data of all DataFields under the node NB, the following commands are sent:
NB/FA=<info for A>; NB/FB=<info for B>;NB/FC=<info for C>; Note that there is a certain amount of redundancy because NB appears three times. To avoid using the node name every time, the following alternative format is used:
NB={ FA=<info for A>; FB=<info for B>; FC=<info for C>; }; The brackets determine the scope of the contained statements. In the above command the statement "FA=<info for A>;" is in the scope of object NB.
Example 2
Consider the following example:
In this example, NB has a child node called NC. To set data to the field FB under NC the following command is sent:NB/NC/FB = <info for B>;
To populate all the fields in NC:
NB/NC= { FA = <info for A>; FB = <info for B>;}; If we want to populate the whole hierarchy with data in one command:
NA = { FA =<info for A>; FB=<info for B>; FC=<info for C>;};NB = { FA =<info for A>; FB=<info for B>; NC = { FA=<info for A>; FB=<info for B>; };};
