The Control Clipplayer Texture Renderer sets a Clip file for the Texture Clipplayer to play.
It should be used instead of the legacy MoViz and SoftClip players as the new implementation relies on the VML player implementation.
To Create a control able Clipplayer Texture instance:
Click on Workspace > Add > Clipplayer Texture.
Drag the new create Workspace item to the scene tree. A new geometry and a phong material are created.
To modify the behavior of your clip player, double click on the workspace item.
Add the Control Clipplayer Texture plug-in to the container to allow control from a control application like Viz Trio.
Control Clipplayer Texture Properties
The Check Change option only applies a new clip if it differs from the existing one. For example, given a template containing a clip filename and a text, if only the text is changed, the clip continues playing if this element is being taken On Air.
