The Control Bars plug-in allows binding of tab field values to the Bar Value fields in Bar Values.
Each Bar Value property in the Bar Values editor is presented as a separate tab field in Viz Trio.
Control Bars Properties
First Bar Field ID: Sets the tab-field ID for the first Bar Value.
Last Bar Field ID: Sets the tab-field ID for the Last Bar Value.
Expose Bars Max/Total Value: Exposes the Bars Max/Total value as separate tab fields when enabled.
