Installing DataPool
First time installation
Run the installation file and follow the instructions. When installing DataPool for the first time three installation types are available:
Typical: install only the DataPool plugin group.
Custom: the user selects the plugin groups that will be installed.
Full: install all the DataPool plugins (all the groups).
Select the installation type and continue.
An information window will display the path of the installation and selected plugin groups.
Note: The plugins will be installed to the plugin directory under the latest Viz installation. If multiple Viz installations reside on the machine, the plugins will be installed only to the latest installation of Viz.
Note: This user guide is installed with the DataPool group.
Upgrade an existing installation
When upgrading the installation three options will be displayed:
Modify: change the installed groups on the machine
Repair: re-install the installed groups (*.dp files will not be overwritten)
Remove: un-install DataPool
Select one of the options and click the next button.
Note: When upgrading from 2.4X version to 2.5X and selecting the repair option, only the DataPool group will be installed. This is caused by the fact that 2.4X versions did not have the plugins divided to groups.
