DataPool.ini File
The DataPool.ini file is installed to the Viz folder and contains the following parameters:
ConfigurationFolder: defines the location of the .dp files to be loaded. If omitted the default path is set to ".\", i.e. Viz folder.
MultiDatapool: Defines if a separate Viz DataPool segment will be assigned to each scene loaded to Viz.
