Datacenter is an end to end solution that allows you to connect live data sources to fields in your graphics, without the need of any special knowledge of the data at hand.
Therefore, Datacenter acts as the gateway between data providers and the Viz ecosystem, automatically translating data coming from heterogeneous sources to format(s) understood by various Viz applications.
Its main purpose is to connect incoming live data, whether from a local source or an online data provider, to fields in your scenes, handling updates in real time. It is ideal to connect to, for instance, a scoreboard on a venue to clock-and-score graphics, or scene effects to data updating in real time.
Feedback and Suggestions
Support
Legal
Copyright ©2025 Vizrt. All rights reserved.
Disclaimer
Antivirus Considerations
Real-Time Scanning: Keep it enabled, but exclude any performance-sensitive operations involving Vizrt-specific folders, files, and processes. For example:
C:\Program Files\[Product Name]
C:\ProgramData\[Product Name]
Any custom directory where [Product Name] stores data, and any specific process related to [Product Name].
Risk Acknowledgment: Excluding certain folders/processes may improve performance, but also create an attack vector.
Scan Scheduling: Run full system scans during off-peak hours.
False Positives: If behavior-based detection flags a false positive, mark that executable as a trusted application.
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
