Datacenter User Guide
Viz Arc Configuration
Each Viz Arc configured as an output in Datacenter, receives live data from it. As data is posted to Viz Arc using an HTTP POST protocol, a valid port must be specified for the Arc Web Server Port field found in Setting > General > Communication of the Viz Arc Configuration panel:
When changing the Web server port, restart Viz Arc to make sure the new changes are applied.
Your Viz Arc is now configured to received data from Datacenter.
Note: Take note of the port specified in the Viz Arc configuration panel, as this is required when configuring the relevant port for the output in Datacenter.
