Document Structure
This section gives a short introduction to the WoC, and what part it plays in the complete CM solution.
The About section gives an overview of the new features and basic workflow.
The Requirements section describes the license, software and hardware requirements for both WoS and WoC.
The Viz Curious Maps section introduces the Viz Curious Maps (CM) application which is the tool for creating map templates with different styles, projections and so on. It also describes how to create a basic template, explaining the connection between CM, WoC and the WoS.
The Viz World Server section describes how to install, run and remove Viz World Server (WoS).
The Server Configuration section describes the map server configuration tool, and in addition it explains how to add a license file.
The Server Launcher section describes the possible server configurations that allow users to configure single or multiple servers to balance the server load and optimize redundancy.
The Cache Configuration section describes the maps caching mechanism.
The Viz World Maps Editor section gives a brief overview of the Viz World Client (WoC), some requirements and recommendations, installation and removal notes.
The Viz World Maps Editor section describes the Viz World Maps Editor (WME) user interface and how to select and edit maps for use with graphics templates and scenes.
The Maps Plugins section describes all plugins available to designers that design Viz Artist scenes. As an extension to the plugins section, you also have a section on Geographically Referenced Maps.
