Viz Plug-in Release Notes
Viz Plug-ins 5.0.1
Release Date: 2022-12-19
These are the release notes for Viz Plug-ins version 5.0.1. This document describes the user-visible changes that have been made to the software since release 5.0.0.
Information: Viz Weather plug-ins are not yet included and need to be installed separately by installing the latest released Viz Weather Version.
This document includes the Release Information for:
Viz Basic Plug-ins
Viz Extensions Plug-ins
DataPool Plug-ins
Socialize Plug-ins
PixelFX Plug-ins
Maps Plug-ins
New Features
Fixed Issues
Fixed Issues: Basic Plug-ins
Changes
There is now only one ControlText plug-in for both Classic and Viz Engine Render Pipelines.
The Text plug-in has been renamed to Classic Text.
Supported Hardware and Software
This software has been tested to run on:
Windows 10 (LTSC 1809), Windows 10 LTSC 21H2
Windows 11
Windows Server 2019
Windows Server 2022
Note: Only English language Operating System(s) are supported.
Viz Plug-ins 5.0.0
Release Date: 2022-09-27
These are the release notes for Viz Plug-ins version 5.0.0. This document describes the user-visible changes that have been made to the software since release 4.4.1.
Viz Basic Plug-ins
DataPool Plug-ins
Socialize Plug-ins
PixelFX Plug-ins
Maps Plug-ins
Installer Notes
The installation wizard guides you through the installation process. Make sure to close any running Viz application prior to the installation. In order to run Viz Artist or Viz Engine independent of a database server, you need to install the Viz Graphic Hub database software locally.
General
The Software ships with a bundle installer containing all necessary components. It is recommended to use the bundle installer when setup needs to be done manually.
The basic plug-ins are installed by default, all other plug-in packages are optional.
Softclip comes in 32-bit (default) and 64-bit versions. To use the 64-bit version, replace the file Softclip.vip in \plugins with the one from the subfolder %ProgramFiles%\VizEngine\plugin\disabled.
Upgrade Notes
The path for the DataPool related files has been set to %\ProgramData%\vizrt\VizEngine\DataPool.
New Features
Basic Plug-ins New Features
Summary |
Key |
ControlText and ControlParameter support for SHM placeholders |
Support "Use All Directors" from ControlObject when saving to Graphic Hub |
Fixed Issues
Fixed Issues: DataPool Plug-ins
Summary |
Key |
Changes
Changes: Plug-ins
SocialTV
The following SocialTV plug-ins have been re-introduced:
WordCloud
Maps
The following Dataproviders have been removed from the Maps Atlas plug-in:
Blom
My Radar
WDT
Upcoming Changes
Known Issues
RTT Shaders consume about 300-400 MB of RAM once they are initialized. If you do not use them or if you don't own a license, it is recommended to disable the plug-ins in the configuration panel in section Plugins (VIZENG-10224).
Softclip: Lagarith Codecs are playing slower on Windows Server Operating Systems. This issue can be solved by enabling Use Multithreading option in Lagarith codec configuration.
The size of certain plug-ins with custom UI (like RealFX, TextFX) do not automatically fit into the new Viz Artist panels, they need to be resized manually.
Basic Plug-ins Known Issues
On Dual channel setups Browser Plug-in causes performance impacts on second or higher instance.
Socialize Plug-ins Known Issues
Viz Engine can't access mapped network shares on Windows 10 for security reasons. If media files are stored on a network share, please be sure to enable Network Linking in Viz Configuration (Local Settings).
Trio 3.x and Viz Artist (UI) do not have full Unicode support yet (e.g. not all Emojis can be set by these control applications).
VLC plug-in requires some additional steps:
Download the archive from VLC: http://download.videolan.org/pub/videolan/vlc/2.2.6/win64/vlc-2.2.6-win64.zip
Extract the zip file and copy all files from:
vlc-2.2.6\plugins to <VizDirectory>\plugins
vlc-2.2.6\lua to <VizDirectory>\lua
Maps Plug-ins Known Issues
When freezing a Map including Pyramids in CWMClient, Hop scenes no longer work (VIZPL-45).
Windows 11
Windows Server 2019
Windows Server 2022
Documentation
Documentation for both Viz Engine and Viz Artist are available at the Vizrt Documentation Center:
Support
