This section contains the Template Wizard’s components and their properties:
- Object Inspector
- Additional Components
- Communication Components
- Dialog Components
- Viz Control Components
- Other Components
- Component Properties
- Import Components
- Standard Components
- Database Components
Note: You can use the Component Palette to customize which components appear in the dropdown list at the top of Template Wizard.
