Version 7.2 | Published May 08, 2017 ©
Pilot Data Server Web Interface
The Pilot Data Server has a Web Interface which can be used to access several of the Pilot Data Server’s features, including the Service Document, Template and Data Element Feeds, Viz Pilot Settings and REST API documentation.
images/download/attachments/28386234/pilotdataserver_dataserver_home.png
To access the Pilot Data Server Web Interface
  • Select the Pilot Data Server Web Interface from the Windows Start Menu.
  • Alternatively, start the Pilot Data Server in a browser, using the host name of the machine running the Pilot Data Server, and port 8177.
    e.g. http://dataserver.example:8177
The Pilot Data Server Home page has links to the following resources:
  • Service
  • Template Feed
  • Data Element Feed
  • Settings
  • Examples
  • Documentation
Service
The Service Document resource (eg. http://<dataserver.example>:8177/service) is an Atom Service Document which can be used by a client to discover the capabilities of a Pilot Data Server and the locations of the available Atom Publishing Protocol collections hosted on it.
Template Feed
The Template Feed resource (eg. http://<dataserver.example>:8177/templates) is an atom feed which contains entries for each template stored in the Pilot Data Server.
Metadata may include details of the template such as description, creation date, link to a thumbnail image and link to the Viz Data Format (VDF) model document describing the template.
Data Element Feed
The Data Element Feed resource (eg. http://<dataserver.example>:8177/dataelements) is an atom feed which contains entries for each data element stored in the Pilot Data Server.
Metadata may include details of the data element such as description, creation date, link to thumbnails and link to the Viz Data Format (VDF) payload document describing the data element.
Settings
The Settings page (eg. http://<dataserver.example>:8177/settings) is used to configure VCP Parameters and Tag Settings. See Setting Parameters using Pilot Data Server for a full description of the Settings tab.
Examples
The Examples page (eg. http://<dataserver.example>:8177/examples) contains examples on how to interact with the Viz Pilot system.
Documentation
The Pilot Data Server Documentation page (eg. http://<dataserver.example>:8177/help) describes the REST API provided by the Pilot Data Server. It includes information on the Resource Types and Content Types that are used in the interface.
The API itself has several features, for example, getting template information, image search and person search. It provides a programming interface for other systems.
